i have this issue
,its quite annoying when having to break at this speed, only requiring a firmer grip.
anyway im sure i read somewhere that there was a solution to this problem.
This was not one of the easyer to diagnose or rectify and the problem i have now is remembering what it was, but i m sure someone said the parts are 35 pound per side, i dont knoe about posible fitting times as i said i cant remember what the parts are, somethin gto do with the hubs maybe?
anyone got a clue on this?
The obvious to check had been mentioned previously.
Check
youre wheel weights are still there,
Check your tye pressures
Check the play in your wheels bearings
(if u have a stable way of jacking the car up)
Have a look for uneven tyre wear on your fronts.
hmmm
Anyone have a clue as to the 35 quid thingys i was talking about
