Yesterday i put 2 amps in the front boot of my mr2 and ran the speaker cable and rca leads through a hole near the drivers feet, As soon as i connected it all up i got the loudest interference noise ive herd from a car audio system.
It did change pitch when turning the wheel so part of the problem i guess is the power steering the cables must run past.
The problem i have though is i could not find a hole the other side of the car to put the cables through also is there any other motors that side that could cause the same issue
Do i have to install the amps behind the drivers seat
I also made the ground wire go to the neg on the main car battery, is this the best way or is it better to ground to under a bolt on the chassis
Any help would be great
