To remove the door card.
remove the small screw behind the door handle and remove the outer trim
take the cap off of the screw on the front edge of the door card
(above and to the front from the speaker grill) and remove the screw, remove the screws along the bottom edge of the door card.
clip out the door pull by levering with a flat screwdriver
(cover the end of the screwdriver with tape to protect door card)
clip out the window control unit using a flat screw driver
, lift the front edge first
(it's clipped in) then pull up and forward to avoid breaking the catches.
disconnect the wiring from the window control unit.
now pull the lower edge of the door card free from it's clips and continue to loosen all around.
remove the tweeter triangle cover by pulling back on the top edge to release the clip then pull free.
reach behind the card and disconnect the courtesy light wiring.
the doorcard should now be free to pull away with some wiggling.
Reverse this to replace.
Just done this twice in the last few days to add courtesy lights in the footwells.
