This has been covered a few times, but here goes.
You can be stock items from toyota if you want, but can't imagine there going to be very cheap tbh.
Another option is to buy KYB inserts which are what most people would consider the budget option.
Expect to pay somewhere around 60 quid a corner.
The
"best" option, considered by most anyway, is to fit Koni adjustables.
These are again inserts, but can be easily adjusted from hard to soft.
Fensport want around
£100 per corner, but if you fancied lowering the car 30mm at the same time, Larkspeed do a set of Koni's and lowering springs plus new bump stops for around
£360, which as you can see is a bit of a bargin.
hth.
