After getting the car back on the road after a few years my P/S motor seems to be much noiser than I remember.
This has also come with another odd bug.
Any ideas on what else could be preventing the motor from switching off at idle?
webb2800 wrote: ↑Sun Oct 02, 2022 12:24 am
This has also come with another odd bug.Per other info I've read on the P/S system, the pump should autmotically switch off if the wheel isn't moved for a while
(and the car is under about 10mph) mine currently runs constantly.
I've got not warning lights and I've followed the diagnostic in the BGB and confirmed the steering postion sensor works as intended.
I've also flushed and replaced the fluid.
I wondered if the P/S ECU was faulty but that apparently usually results in no P/S at all and/or a warning light.
I'm pretty sure the motor is switching off as intended at high speed but it could be noise from the engine masking the sound.
EHPS(ELECTRO HYDRAULIC POWER STEERING)
SYSTEM OUTLINE
THE EHPS(ELECTRO HYDRAULIC POWER STEERING) SYSTEM FUNCTIONS TO CHANGE THE FORCE REQUIRED FOR STEERING MANEUVERS, AND THEREBY PROVIDE THE IDEAL STEERING FEELING FOR AT VEHICLE SPEEDS AND STEERING CONDITIONS.
THIS IS DONE BY THE POWER STEERING ECU CONTROLLING THE HYDRAULIC PRESSURE ACTING UPON THE HYDRAULIC REACTION CHAMBER
(LOCATED IN THE GEAR BOX CONTROL UNIT) BY REGULATING THE POWER STEERING MOTOR’S SPEED
(AND HENCE THE AMOUNT OF FLUID FLOW).
EHPS OPERATION
WHEN THE IGNITION SWITCHED ON, STARTING CURRENT FLOWS FROM THE GAUGE FUSE TO TERMINAL IGB OF THE POWER STEERING ELECTRONIC CONTROL UNIT, TERMINAL VS OF THE STEERING POSITION SENSOR, AND TERMINAL(A) 4 OF THE POWER STEERING DRIVER.
THE VEHICLE SPEED IS DETECTED AT THE SPEED SENSOR, AND SIGNALS ARE INPUT AS CONTROL SIGNALS TO TERMINAL SPD OF THE POWER STEERING ELECTRONIC CONTROL UNIT AND TO TERMINALS SS1 AND SS2 OF THE POWER STEERING ELECTRONIC CONTROL UNIT.
WHEN THE ENGINE IS STARTED, SIGNALS ARE INPUT TO TERMINAL EFI OF THE POWER STEERING ELECTRONIC CONTROL UNIT FROM THE ENGINE OF TERMINAL PSCT OF THE ENGINE AND ECT ECU.AS A RESULT, THE CURRENT APPLIED TO TERMINAL IGB OF THE POWER STEERING ECU FROM THE GAUGE FUSE FLOWS FROM TERMINAL MRLY OF THE POWER STEERING ECU
→ TERMINAL
(B) 1 OF THE POWER STEERING RELAY
→ TERMINAL
(B) 2
→ GROUND, AND THE POWER STEERING RELAY IS SWITCHED ON.
(A) 1 OF THE POWER STEERING RELAY FROM THE ABS FUSE FLOWS FROM TERMINAL
(A) 2 OF THE POWER STEERING RELAY
→ TERMINAL
(B) 1 OF THE POWER STEERING DRIVER AND TO TERMINAL
(A) 1 OF THE POWER STEERING MOTOR.
IF THE VEHICLE SPEED IS LOW, THE SPEED OF THE POWER STEERING MOTOR IS INCREASED BY INCREASING THE VOLTAGE OF THE CURRENT THAT FLOWS FROM TERMINAL(A) 1 OF THE POWER STEERING MOTOR TO TERMINAL
(A) 2 OF THE POWER STEERING MOTOR
→ TERMINAL
(B) 2 OF THE POWER STEERING DRIVER
→ TERMINAL
(C) 2
→ GROUND, WITH THE RESULT THAT THE VOLUME OF FLOW OF THE POWER STEERING FLUID BECOMES GREATER, THUS PROVIDING A LIGHT STEERING FEELING.
WHEN THE VEHICLE SPEED IS HIGH, THE SPEED OF THE POWER STEERING MOTOR DECREASES AS A RESULT OF THE REDUCED VOLTAGE APPLIED TO THE POWER STEERING MOTOR, AND THUS THE VOLUME OF FLOW OF THE POWER STEERING FLUID IS REDUCED, SO THE STEERING FEELING IS MORE RESISTANT.
