Hi all,
As per the title, this year the NA will hopefully get an A/C retrofit.
I presume this will be a difficult project with a million bits to source and by the time it's done it will be winter
- but I like a challenge and even in the UK a T-bar gets sweaty very quickly.
I was going to start getting everything together with a new condenser and pump.
Rock Auto seems to be the best place for the condensor, that doesn't seem too complicated.
I did want to check though, will a Turbo pump fit on the NA mount? I presume they are the same, but it's an expensive kit to order on a hunch.
I'm looking at getting this kit:
https://www.rockauto.com/en/moreinfo.ph ... 07&jsn=838 I have a Rev4 Turbo as well with A/C
- it looks like the pump would fit, but I'm not 100% sure.
I'm not looking to retro-fit full climate control
- just the manual A/C on/off button to the existing heater controls.
I realise also that when
(if) I manage to get it installed, it will need attention from a technician to commission the system before use.
TIA
Joe
Current MR2s:
2018- Rev 5 UK NA
2018- Rev 4 Sonic Shadow Turbo
Previous:
2014-2015 Rev4 UK NA
2001-2010 Rev2 Turbo
