Hi everyone, new on this forum, but long time owner.
So here's a really odd one.
Just before the lockdown started in March, I had a new clutch fitted to my Rev2 Turbo.
I decided to go with a stage 1 Exedy, as a means of future-proofing, in case I run more boost at some point.
The work was carried out by a very well-known MR2 specialist here in the North West, well, technically he's in North Wales, I'll leave it at that.
Parts were supplied by the garage, except the fluid, which I asked to be flushed out for some Castrol SRF that I provided.
My issue is as follows.
I set the biting point myself so that it would match the point from the old clutch, and it does
(about half way up the travel of the pedal).
However, as the engine warms up, the bite point moves up as well.
At normal operating temperature, the clutch bites at the very top of the pedal's travel.
And I mean literally AT THE TOP.
If you're driving along, as soon as you barely touch the pedal, the clutch disengages.
It's incredibly annoying! Once the engine has cooled down, biting point returns to normal
(about half way), and then when I drive it again, as the engine gets up to temp, bite point steadily moves up to the top of the pedal again.
Spoke to the garage on the phone, they said they'd never had this happen and that they could look into it.
Now the car is actually there for some other work, and they tell me that this is how uprated clutches behave, and that it's normal.
They even claimed it's the same principle as having more aggressive brake pads, where the friction material grabs more with heat.
And that's when alarm bells started ringing!!! I have Pagid RS29 pads on my other car and know exactly how they behave.
If what they claimed was true, the effect would be the exact opposite.
There's no leaks anywhere in the system, and part of the bottle of brake fluid I supplied, I had actually used in my other car a week prior, so I am positive it has nothing to do with that.
I truly hope someone can shed some light on this.
I like this new clutch, but am now seriously thinking about biting the bullet and going back to a stock clutch.
Even if you don't know what the problem could be, do you think this is normal by any chance, because it certainly doesn't make any sense to me.
