Yellow JDM 94 turbo
3sgte
420@ The hubs.
CP pistons 9:01
ARP head studs
Block acid dipped, decked and honed
Polished crankshaft
Clevite 77 crankshaft bearings
Toyota steel head gasket
Custom chargecooler setup with massive core
Bosch CC pump from AVT
AVT pre-rad
BW 252sx-e Turbo
Custom downpipe
Turbosmart Ultrgate 38mm
Berk exhaust
SARD 800cc injectors
Sytec FPR
AEM 340LPH in tank pump
Custom side feed inlet manifold
90mm Q45 Throttle body
Link G3 Plus ecu with launch control
Coil on plug conversion
All new seals, belts, pumps and pulleys.
Head ported and polished
Valves relapped and supertech valve stem seals fitted
Stock turbo cams
Twin engine lid fans
Clutchmasters FX400 six puck clutch
Meister R CRD Zeta Coilovers
Powerflex polybushes everywhere possible
New Spherical bearing
Supra 323mm front discs
200sx Front calipers
Lenso D1r Wheels
Toyo T1R Tyres
Interior stock except some daft stickerbomb wrap over the centre bit.
Round Gear ring from an Audi TT
Abflug wide arch kit all round except front bumper
Border front bumper
Resprayed in the rev2 signal yellow with pearl powder added to the paint.
All of the above carried out at 100,675 miles.
Kenwood DMX 7017DABS Head unit with apple carplay, dab radio etc.
Vibe Slick 6 front speakers, alpine rear speakers.
10inch and 8inch sub behind passenger seat powered by 1000watt vibe micro amp
https://www.youtube.com/watch?v=x728lh_A97c
