A new member and my first time on here.
I bought my roadster last May and had great fun driving it until SORNed it in November.
Since then it has sat outside and with no problem at all and I have periodically started it and run it.
Yesterday I went to do the same after several weeks but I had left the battery connected and there was no power
No problem.
This morning
Still turns over nicely with the aid of the Mondeo but no ignition.
Does this ring any bells with anyone please?
I have had a plug lead off and seen a spark.
I've looked at fuses and they all seem ok
I took the air filter off and squirted easy start down and got about a 4 second fire
I've taken the ECU fuse out and then replaced it later
More clues
At one point the alarm module in the front luggage compartment was making a weird noise
When the ignition is off there is still an electrical whirring noise coming from mid engine
Have I fried something?
Many thanks if you can help shed light on this
Kind regards
David
