rev3
rev3
my rev3 turbo has started to throw lots of oil out of the catch can which I have venting to the air, my first thought was piston rings but a compression test shows all cylinders to be within 2psi of each other, the car still pulls well without any smoke and all turbo/inlet hoses are completely dry from oil, anybody any idea what could be causing this problem
Re: rev3
1) What are the compression test results?
(ie.
The cylinders are consistent, but could they be consistently low?)
2) Is is the stock catch can? If is isn't, does it need emptying? If it is, might the drain back to the sump be blocked?
rev3
shinny wrote:1) What are the compression test results?(ie.
