After a bit of advice really.
Just put my rev 3 turbo back on the road after 6 years and everything was reasonable.
Not making full boost around 12psi in 3rd(has manual boost controller set to 17 psi).
Whipped off the intercooler pipes to re seal, checked a few vacuum hoses etc and when restarted car neither the stock boost gauge or aftermarket one is working? The aftermarket gauge is tee off the map.The car is making boost on a short drive.
Any pointers or ideas.
Map sensor wiring perhaps? I've checked hoses.
Ive also plugged the diagnostic which is showing code 21
(02 sensor) which I need to clear and see if it returns
