Its got screw terminals on the back for easy connection.
You will need SR20DET sensors.
IF i remember correctly those white tabs on the back need to be cut to fit it on the MR2 din slot, so its not a direct fit.
35 posted.
shinny wrote:The screws aren't supposed to be the terminals.They hold the gauges themselves in place and transfer the electrical signals.
To get these to work, you would be wise to source the sensors from a Pulsar.There's no guarantee Toyota sensors will get even remotely the correct reading and don't even think about patching them into any of the sensors used by the ECU.
androo007 wrote:isnt stock boost 8psi?
ellisd1984 wrote:I'll take them
