Is there a walk through Or a thread available please as im having difficulties with a loom plug in the boot no longer marrying up.
I'm sure I will run into more difficulties.
PW@Woodsport wrote:In 20 years i have yet to swap the kickwell loom on any turbo conversion, just repin the engine harness to suit, far less likelyhood of other issues occuring.
Also you can simply use the NA gear cables with the addition of a simple 12mm spacer on the gearbox cable bracket, no need to buy turbo cables.
alanmr2turbo wrote:PW@Woodsport wrote:In 20 years i have yet to swap the kickwell loom on any turbo conversion, just repin the engine harness to suit, far less likelyhood of other issues occuring.
But he wants the easy way, not farting around with repinning, en asking which pins to repin and not making a brackets for cables lol
By the time you have repimmed the look I could have fitted the cable especially if you had to first find which ones to repin.
