I have just purchased myself a wee project MR2, a 96 uk car, but its in bit of a state!!
I am happy working with the oily bits, but its the body work am not so sure of, and need some advice.
It requires a few patches and inner/outer sills, thats bad enough, but its had a slight accident, damaged to the front passanger side, the bumper is cracked and it also bent the cross member rad sits on, quite bad, I also have discovered the quarter panel has also had filler in the past
I know all of this can be fixed, my question is how to tell if the chassis is bent or would you lot put in a Jig and checked out anyway
Pete
