I want to change the stat 1st but don't know what size I need.
My car is a 1995 NA G-LTD import.
MR2 Ben shows a 64mm 82'c for this, can anyone confirm if this is correct for my car.
almeida1234 wrote:Best to give the reg no when ordering so you can have the right one(unless u had a engine swap etc) smaller one tent to be rev1-2 and larger one is rev 3 onwards
Gazza_DJ wrote:OEM PN 90916-03100
Check yourself here: http://japan-parts.eu/toyota/jp/1995/mr ... t/2#16331A
Toyota used the same one on lots of engines, just pick one up from the dealer.They probably have it on the shelf.
firebobby wrote:almeida1234 wrote:Best to give the reg no when ordering so you can have the right one(unless u had a engine swap etc) smaller one tent to be rev1-2 and larger one is rev 3 onwards
Thanks, I did and the vin no to a ebay seller and they still say it"should" fit.
I have messaged TCB after checking old posts on here, hopefully they can help
Cheers![]()
pbmr2 wrote:firebobby wrote:almeida1234 wrote:Best to give the reg no when ordering so you can have the right one(unless u had a engine swap etc) smaller one tent to be rev1-2 and larger one is rev 3 onwards
Cheers![]()
TCB are great, but they are best if you call them.
