After 2 years of nearly not using it, decided to sell my MR2.
The car is a 1994 rev 3 import NA GTS with a 1995 rev 3 turbo swap on it.
Chassis has 129500 km
The swap has been done in 2015 with around 121600 km on the clock
With the swap had all new fluids
After the swap i refurbished the rear calipers with new Brembo pads, new handbrake cables and Meister R coilovers.
With the May 2017 MOT had refurbished front calipers and Brembo pads, new oil and filter and spark plugs and new rear tyres.
Spec:
1994 rev 3 NA chassis, 1995 rev 3 engine with complete loom, turbo lsd gearbox and axles.
Upgraded side mount intercooler with custom pipework
Original HKS SSQ blow off valve
Berk SS decat downpipe
Mongoose SS exhaust
Custom air intake with Honda S2000 air filter
Bluetooth OBD readed integrated in the engine loom
Meister R coilvers
JDM 3 piece 16" BR sports wheels, Avon ZV5 front 205 50 16
The car is mechanically sound, no smoke, never used a drop of oil, pulls like a train.
The only thing that doesnt work properly is the AC.
The bodywork is good, as you can see on the pictures i cant see rust anywhere other than the typical surface rust on some of the suspension arms.
Paint is red, still polishes well, i would say its ok for the age.
Im looking for around 3450
Thats probably one of the cheapest turbos around, reflecting the lacquer peel and the fact that is turbo swap.
Pics here https://imgur.com/a/ArZBaPL
