Thanks.
markstevieandmads wrote:tcbparts
simpson_eh wrote:not usually the pump, have you tried the on off trick like 50 timessad but it works lol
tiff_lee wrote:So the power steering motor/pump is definitely running?
Does the power steering light come on with the ignition they extinguish once the car is started?
There is nothing to the physical pump part of the motor/pump assembly, in fact that goes for the whole lot really.
Seems odd your steering is'stiff' yet you changed the entire rack and pump assembly a few years back, then fitted another replacement pump/motor from the US, there must be some common denominator here i.e the control circuit
(hence check power steering light).
Also be aware that although the motor/pumps have the same physical connectors some are actually wired up different which will prevent them running and leave you with a power steering light on and fault code.
Juliuswws wrote:forums/viewtopic.php?t=194300&sid=c3f51 ... 91a63a534b
I guess it would worth a try
tiff_lee wrote:Yeah there is no difference between the pumps themselves as in the mechanical part bolted to the motor but there IS a difference between motors.Some have additional wiring which I presume is for current feedback to the ECU.
I'm not sure what metric you're using to judge the'stiffness' there really is nothing to the power steering system and if you have replaced every component then the fault is most likely elsewhere, i.e in the control system and the motor not running as is should.
I'd be tempted to jumper 12V to the motor so it runs constantly, go for a drive round the block and see if any difference.
tiff_lee wrote:Yeah not sure what they'repaired' on the vane pump there is nothing to it! i'll post some pics later need to upload off my phone.
Also unplug the connectors for the motor as well when you jumper the 12V to it, if you see an improvment with the steering after doing that it's defintely a control issue(so reference that ECU thread).
tiff_lee wrote:Not sure why it needed machining i've never heard of anyone having that done, the ends are rounded slightly are run inside a smooth round spacer thingy.
Anyway if you have changed pumps already its very unlikely both have suffered from the same failure mode.
tiff_lee wrote:I bet he would if he is convincing people to pay for'repairs', you are the first person i've heard of having one done.
Anyhow, give the direct power supply and a go and see what happens.
tiff_lee wrote:I need to create a thread on rebuilding my power steering rack and motor but in the mean time here is a couple of pics.
The vane pump, not sure what is being machined by the mechanic over there
https://i.imgur.com/FAPvaAI.jpg
and 2 different motor tops, which without modification would be incompatible with the car it's being fitted to(as pinout is different).
Both have sensing line on the+VE supply
(red wire) but the bottom one has 2 wires tapping off the
-VE rail
(green
& white).
https://i.imgur.com/ocWJNPB.jpg
https://i.imgur.com/fc8hnQA.jpg
