[Mk2] [NA] MOT fail - emissions - help assessing level of failure
Racer7
Post by Racer7 »
Hi guys,
Put my UK N/A back on the road after a couple of years of being SORN I have failed my MOT on the dreaded emissions part.
I am currently assessing my repair list but before that I wondered just how off I am of passing.
I did think that the car probably wasn't hot enough. Had old fuel that perhaps hadn't fully burnt off.
One thing to know which is perhaps a big cause is previously when I MOT'd it the tester said there was some emissions leaking from the CAT and back box connection. It's Mongoose SS exhaust with the OG cat welded in a fashion to therefore be a cat'd aftermarket exhaust
Here are my results:
https://drive.google.com/file/d/1GYqXs5 ... sp=sharing
My instinct is to change crush gaskets and fit a new lambda - based on what readings seem to be most out and the info above.
Wondered what the thoughts of the experts are?
SonicSW20
Re: [Mk2] [NA] MOT fail - emissions - help assessing level of failure
Post by SonicSW20 »
Check the exhaust system for leaks thoroughly - even a small hole in the backbox somewhere is enough to throw the lambda value out a lot. You can test the o2 sensor with a multimeter (process in the workshop manual) to confirm it's functioning.
Agreed on the heat issue - As you can see on the 2nd fast idle test both HC and CO dropped significantly, suggesting the cat was not up to temperature. A good old fashioned Italian tune up just before testing will solve that.
Racer7
Post by Racer7 »
Gazza_DJ wrote: A good old fashioned Italian tune up just before testing will solve that.
Thanks for swift response. So the Italian tune is an actual thing. That's where you drive at high revs in first and second right? Someone suggested that speed is also quite an import part of it. Ie I can't just rev to 30MPH - not sure how important or true that part is.
Need to find a decent garage now to switch out the crush gaskets. I'm hoping that the car will get through on some minor changes.
:pray:
pbmr2
Post by pbmr2 »
All good advice above..
Stick some of this in the tank before the test day and make sure it's driven enough to pull though to the injectors by the test time.
This stuff works magic.
https://www.amazon.co.uk/Forte-Lubrican ... as+formula
make sure you get rid of the old fuel, it really doesn't help as it under-burns so high HCs
exhaust leaks are evil..
Racer7
Post by Racer7 »
pbmr2 wrote:All good advice above..
What is considered as 'driven enough'?
I'm wondering whether i should have insisted that they ran it again. But i suppose I'd just be putting off an inevitable problem.
pbmr2
Post by pbmr2 »
depends.. how much old fuel was in the tank?
How full is the tank now?
If the old fuel was topped up with new, was super used?
normally it starts working after about 5 miles, have to add it before topping up with fresh fuel. helps the mixing.
wilkie senior
Post by wilkie senior »
I would concurr with all the above, mine doesnt get driven too much, and i had the same at the last MOT
they put some wonder juice in the fuel tank, and I drove for a while all seemed ok a couple of days later
mr2garageswindon
Post by mr2garageswindon »
Also with the high lambda, if you have a twin exit exhaust sometimes its worth blocking the other exit with a rag while doing the test.
Racer7
Post by Racer7 »
Thanks all.
I'm going to the tests Gazza_DJ recommends and see if i can just put some high temp sealant at the suspected leak point by the crush gaskets.
Feel like i should have insisted that the tester ran it again. not like I can now just borrow the equipment from someone to test it's in range!
I either have to move closer to Pacific Works/Drift Limits or they need to come closer to SW London!
wilkie senior
Gazza_DJ wrote:Check the exhaust system for leaks thoroughly - even a small hole in the backbox somewhere is enough to throw the lambda value out a lot. You can test the o2 sensor with a multimeter (process in the workshop manual) to confirm it's functioning.
Good advice, this :+:
