Pre and post facelift are different subframes.
The main difference is that the post facelift has more underbody bracing, and as a result there are mounts for the additional braces on the later subframe.
You can run a pre facelift subframe on a post facelift car, you just lose the extra braces.
When mine rotted through I ran a pre facelift frame I picked up for cheap for a while until I found a decent post facelift one.
I ended up buying a brand new one from Camskill at half the price it would've been from Toyota
(they are about
£280 new from Mr T if I remember right).
Unfortunately for you, Camskill don't do OEM parts anymore.
Post facelift subframe part number is 51206-17040.
