[Mk2] [Generic] ECU Capacitors
dex
Post by dex »
Hopefully this may help someone else. When my engine started running roughly and not wanting to start I checked for error codes and found code no. 14 (No IGF signal to ECU 8 - 11 times in succession). Whilst looking for an igniter I came across various threads about the capacitors failing in the ECU so I checked mine and found capacitor C895 leaking with track damage to the PCB. Capacitor C816 had a minor leak just starting too.
Rather than replace the capacitors myself I found a PCB repairer in Sheffield ( http://www.nova-electronics.co.uk ) on the internet and sent my ECU to them along with the eight replacement capacitors listed in this thread https://www.clublexus.com/forums/ls-1st ... ost7496164
The ECU was successfully repaired with the leakage neutralised and the damaged track fixed for under £100. As a preventative measure I had the other six capacitors replaced at the same time. Nova don't coat their repairs with conformal coating so I bought some acrylic PCB sealer (under a fiver delivered) and did that myself.
killerferret666
Re: [Mk2] [Generic] ECU Capacitors
Post by killerferret666 »
Can you list / link the ones you bought / got. Im not 100% sure based on the lexus thread.
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
dex
Post by dex »
Rev 3 ecu electrolytic capacitors and suggested replacement part numbers. The replacement capacitors may have higher voltage ratings than the originals.
Main Board:
C002 = 63v 47uf - EKZE101ELL470MJC5S or EEU-FC2A470
C004 = 35v 33uf - EEU-FR1V330 or 100ZLJ33M8X11.5
C101 = 10v 100uf - 35ZLH100MEFC6.3X1 or EEU-FR1H101
C105 = 10v 220uf - UHW1H221MPD or EEU-FR1H221
C816 = 50v 10uf - EKZE500ELL100ME07D
C823 = 35v 15uf - EKZE630ELL150ME11D or UPW2A150MPD
Daughter Board:
C894 = 10v 100uf - 35ZLH100MEFC6.3X1 or EEU-FR1H101
C895 = 50v 10uf - EKZE500ELL100ME07D
Nova will source low ESR capacitors if you ask them to but they won't necessarily be the same as the ones listed in the Club Lexus thread.
killerferret666
perfect thanks for that.
its my C816 thats started to leak - or is leaking.
killerferret666
In case anyone is after these, i ordered all 8 from
mouser.co.uk
They do come from america (couldnt find UK place) and came to £17.50, delivered was £12 but arrived within 2days.
killerferret666
I actually found it hard to find anyone to do PCB repairs, the 1st place had the ECU almost two weeks and with this good weather Id had enough so told them id collect it and find someone else to finish the work, 2 weeks for 8 capacitors is too long.
Anyway the work was horrible, blatently not a hot enough soldering iron was used. I found a new guy who would do the work and did it quickly for me as well. He also tidied up all the other guys work and the soldering looks like the originals.
I told him after id put his website up on here, If you end up sending your ECU to him he will know what to do at least. Was reasonably priced as well.
http://techmedics.co.uk/
(poole based but can always send the ECU) They normally repair xboxes, playstations etc... which is much more on the micro scale.
chrisE
Post by chrisE »
Thanks for the info guys. Do those part numbers also apply to the rev3 turbo?
killerferret666
chrisE wrote:Thanks for the info guys. Do those part numbers also apply to the rev3 turbo?
I got those ones for my Rev3 turbo and ECU has been fine since.
Return to “Electrical”
