Temperature always stays normal
It idles just over 1k rpm
EML flickers on and off randomly throughout a drive but never stays on
Im thinking maybe head gasket is on its way out or turbo
AdsMr23sge wrote:I've found a local mr2 specialist near me that I'm dropping the ECU off to tommorow so he's going to have a look and fix it hopefully
It's strange how it's been running recently had high idle engine light flickering but never cut out untill last night it literally fired up ran low idle and really lumpy(sounded like it wasn't running on all cylinders) then cut out
, I couldn't start it again I'm now wondering could this be anything else other than the leaky capacitors like a snapped cambelt maybe?
The leaks seem to have stayed near the area of the effected capacitors both have black goo on top of the original solder points and one on the small board c512 has black down some of the lines near the capacitor if that makes sense?
