1994 Revision 3 GT-S in 3E5 red
For sale is my Rev 3 GT-S.
I've owned the car for several years now and it's been up and down the country.
I'll list the details and then explain a bit more about the car and my reasons for selling.
The car is located in Suffolk just off the A12 near Saxmundham.
1994 Revision 3 GT-S T-bar, 3E5 red
FSH/receipts for it's UK life, imported 2006 with service log from Japan
Forged build with JE 86.5mm pistons
Garrett GT2860RS internally wastegated
Blitz Dual SBC
New goodridge oil drain and water hoses for turbo with firesleeve
(genuine; not ebay)
New coolant bypass hoses
("hose from hell" and
"hose from hell on earth")
Custom 3" downpipe
Apexi GT exhaust
255LPH fuel pump
SARD FPR
(genuine)
-6 braided fuel lines
SARD
(Denso) 850cc high imp.
injectors tested and flow matched
New Toyota fuel filter
Apexi power intake
HKS SSQV
Recent ignition refresh
Pre-compressor water injection with solenoid valve
Intake manifold has 1/8" NPT bosses TIG welded into the runners for the option of direct port water/meth injection currently sealed with 1/8" blanking plugs
I can also supply four-branch water manifold block and smaller nozzles with the car depending on agreed price
Boot mount water injection reservoir, filter, pump
Apexi Power FC
- mapped my Ryan G on 540s; 292whp in a very warm room.
Can supply this map if you want to revert to 540cc.
Recent shift bearing kit and cube rotation
Tein Super Street adjustable coilovers with Tein pillowball top mounts
Yokohama Advan SA3R with nearly new Toyo R1-R tyres
Prothane bushes front and rear
- the front ARB bushes weren't fitted and old ones left in so I had to ask trader to supply them separate
- will include
Recently blasted and painted front and rear subframes and arms
EBC red stuff pads and grooved discs
Honda DC2 Recaro SR seats in red
A-pillar pod with oil temp and boost gauges
Raybrig headlights
Alpine headunit MP3/iPod/CD/etc
Things that require attention:
Has had a sill and arches resto in the last few years but O/S outer sill requires attention
T-bar seals will need replacing soon
- intermittent leaking driver side
Various little scuffs and blemishes on the paint but overall very good for a 3E5 car
Central locking doesn't work since the car is back but likely that the workshop neglected to plug the control box back in when refitting interior
Passenger a-pillar courtesy handle thing is loose
Alignment needed since suspension rebuild
Car isn't mapped on the current setup
(850cc).
The characteristics of these injectors are quite different from the Toyota ones so it's not just a simple case of adjusting the injector scaling in FC Edit.
It requires proper calibration.
I did drive the car back from the trader's workshop but it's barely driveable and needs calibrating.
The gods conspired to make me miss two calibration sessions up at EFI Parts in Runcorn, and many hours of miserable driving for nothing, after which I had to admit defeat and resented any more of my time, effort, or money going into this car.
I was already fed up with the time it had taken to get around to even starting the work
(it was at the shop about 18 months in total).
I just never took the final steps to get it going.
The larger injectors and fuelling upgrades were to insure a bit more overhead on injector duty at full boost but I guess that's for the next owner to take advantage of.
I've recently changed careers which involved a decrease in income and moving, so I have to accept that it's just not practical to hold onto the car when it's taking up space and all it's recent work and parts now going to waste.
I've had some good times with car, but it's time to move on.
I just wish it had been under better circumstances.
I'm firm on
£4500 or
£4000 if you bring your own wheels with tyres.
The MOT ran out on Feb 16th and the car is currently SORN.
This is a car with much spent and refreshed and only a few steps away from being on the road again and as such, a lot of work that would be required on similarly priced or cheaper cars has been done here.
Please message me on here with any inquiries.
Kind regards,
John
PICTURES
