light on "check engine" today. already checked faults and get
21 O2 sensor
22 Water temp sender
23 ??? have no ideas
24 air intake sender
31 air flow mater
52 :/ thats why i guess light is on all the time
all thats sound like my car ECU is xxxxx up
now car is pulling like a devil. after light on she gain alots power seem like
any ideas guys to sort out this xxxx
52 is knock sensor, will pull great till quarter temp then goes to limp mode if knock sensor is dead def will not give extra power,
you need to clear all the codes and see what new codes pop up as some of them could be old stored codes
