As per title, suddenly the lights dropped dim and battery meter reading about 11 volts, but didn't continue dropping, just running lower on charge than it should.
I have a reconditioned alternator in there, only about 2 months old ish.
But when I checked for a loose belt, tension was fine but noticed the alternator casing is ridiculously hot.
Any ideas please.
