My Mk2 Turbo developed an oil leak.
BUT.
Any ideas?? I assume I didn't need to add any sealant or anything.
Thanks!
Tim
tiff_lee wrote:UV dye to find an oil leak? you added some dye to your oil? oil leaks are obvious enough without that.![]()
tiff_lee wrote:Anyhow not much to the gaskets if they are the right shape then chances are they are the right gaskets, are the gasket surfaces/faces square though? i.e not warped etc
