[Mk2] [Turbo] Handbrake spring which one is fitted correctly?
killerferret666
Post by killerferret666 »
Since i built the car ive always had one handbrake grip better than the other, I thought it was the load balancing design id done was poor, until yesterday when i saw this.
I presume the one with the spring hooked in the square is correct?
What is the force like on these springs am I going to be able to reposition it with pliers or need a special tool?
I believe to be correct:
https://i.imgur.com/SDYj3eqh.jpg
I believe to be wrong
https://i.imgur.com/m8hgPJNh.jpg
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
pbmr2
Re: [Mk2] [Turbo] Handbrake spring which one is fitted correctly?
Post by pbmr2 »
in the hole...
killerferret666
arrows on the wrong bit im asking :D but your photo does give me the answer that the other end should be in the square.
Anyone any idea on how strong these springs are, I dont want to ping it off and not be able to get it back on
pbmr2
Post by pbmr2 »
not my arrow, just a pic found on the net.
They are not too bad, you can move the arm with your hand. Should be able to man handle it into place.
killerferret666
pbmr2 wrote:not my arrow, just a pic found on the net.
You were on the ball. for everyones knowledge. It was a tight fit to get off and I thought this is going to be a nightmare to put back on, but sure enugh with that little less tension it went on easy.
Handbrake now working equally on both sides
pbmr2
Post by pbmr2 »
Had this sort of fun with my calipers last year, only just managed to get it through the MOT it was that bad. Still all sorted these days :D
Glad you got your's sorted too
