Ive run it on a ct26 and CT20b with no issues.
At first I couldn't tell what had changed as normally there is a slave board or something and it looked quite stock, but then from the human soldering I could see the main chip had been changed.
jon wrote:If the part number on the main chip is D151802-9361 then that's the normal part.
I'd suggest that at some point in the past it has had a daughterboard fitted but for some reason it has been removed and the main chip re-soldered back into position.
