Hi guys,
I have just bought a rev 3 turbo - Mods are: *blitz nur spec - cat still in play *SARD dump valve *HKS Mushroom filter *APEXI AVCR
The car doesn't seem to boost over 0.5bar/ 7.25 PSI - Now I read loads of different posts some that contradict one another. What should my first check here be to get my car boosting above 0.5 bar?
I have found a lot of things saying T-VSV but surely mine is no longer in play with the APEXI?
Any help welcomed
First thing I would do is look for a boost leak.
Inspect all pipework and clamps to look for anything loose or popped off. Ideally you want to pressurise the intake as this will make it easier to spot\hear any leaks.
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
There are a few ways of doing it, but I cut the bottom off an old baked bean tin, fitted a Schrader valve and then inserted this into the intake pipe to the turbo and attached to my compressor.
Obviously stock turbo pressure is only around 14psi, but if you can pressurise to around 20psi then it can help to spot issues.
Blue Lexus RCF
if it's not a boost leak (the silicone vac hoses split easy, check them) then it could be plumbed in wrong and only using actuator pressure. your boost level is almost exactly stock actuator pressure.
