Those of you that already use Fuchs Oils will be aware of the quality of their products, especially if you are using their
Titan Race Pro range
Well, we are pleased to inform you that
Opie Oils
are offering
15% off ALL Fuchs Titan Race Pro S and Pro R engine oils!
Be quick, this is for a
limited time only
To get this discount, all you need to do is use the code:
OILPRO
at checkout! Unfortunately, your forum discount cannot be used in conjunction with this.
One of the most popular choices in this range is the
Fuchs Titan Race Pro S 5w-40
Originally, 5 litres of this was
£46.99 but with the discount it is now
£39.95! Another very popular viscosity is the
Fuchs Titan Race Pro S 10w-50
- this was
£47.95 for 5 litres, and is now
£40.76!
Fuchs engine oils meet the latest and most demanding specifications set including the latest ACEA C1, C2 and C3 low SAPS approvals.
Opie Oils are official distributors for this prestigious brand, so if your vehicle is getting fast road use, track days, or competition use, we've got you covered whatever your set up or level of modifications!
There is an array of benefits to be gained from using these fully synthetic ester based oils, some of which include:
- Enhanced anti-wear properties
- Outstanding temperature protection and cold start characteristics
- Suitable for use in turbocharged and normally aspirated diesel and petrol engines
- Increased fuel economy
- Reduced emissions
- Ester content creates surface-active layer, meaning a thin layer of oil on the surfaces at all times
Every oil you will find in this Titan Race Pro range including the Pro S and Pro R oils, is a fully synthetic, ester based high performance engine oil providing optimum protection for extended engine life and reliability
- with the added bonus of having 15% off! Simply click
HERE
to see the entirety of what we have to offer.
Below are links to each of them:
Fuchs Titan Race Pro S 5w-30
Fuchs Titan Race Pro R 15w-50
Fuchs Titan Race Pro S 10w-60
Fuchs Titan Race Pro R 10w-40
Fuchs Titan Race Pro C3 5w-30
If you need a bit of advice on choosing the perfect oil for your particular vehicle, give us a call on
01209 202 944
Monday to Friday, 8:30-5:30 or drop us an email to
[email protected]
and we can provide a free bespoke recommendation for you.
That's all for now folks!
- Oilman
