OK, my twopence worth.
Can't quote as i was going to since as usual, posts on this thread come and go, so it'll have to be best i can.
Yes Craig, nearly 5 years ago you came to me wanting
"the ultimate MR2 T Bar".
I seem to remember suggesting either:
starting with a mint Rev5 UK car.
Stripping it, painting it, and moving everything across from your car.
Or
buying a late turbo and moving everything across from your car, and then selling your car.
Both options expensive.
But instead you chose a shell that had been in my yard for around 5 years.
No leaks through the tin tops, but knee deep in mulch from the chestnut trees above it, and more living plants in the frunk than my neighbour's greenhouse.
But best of all
- it was FOC and on the premises, so no acquisition or transporting costs.
You spent at least 4 or 5 Saturdays stripping it.
We then went round it and discussed what needed doing to it.
3 areas required attention
- radiator support panel, mid-sill and rear sill.
To save money you paid to have the two areas repaired that had to be done, and decided to leave the rear sill at that time as it wasn't that bad and you
were fitting skirts anyway.
You chose that shell
(following an inspection one presumes), spent days stripping it, stood around it discussing what needed doing to it, but were unaware there was corrosion on the rear of one sill?
But wait, there's more.
Last year's MOT certificate noted the sill corrosion as an advisory.
So in addition to not knowing about the corrosion, are you also claiming you didn't look at your MOT certificate either?
In Craig's world, where there is nothing but Craig and a MR2, Craig might believe that, but anyone in the real world that knows Craig, will know that's BS.
Back to the MOT.
Now, having known Neil, my MOT tester for at least 10 years, i dare say i could have swayed him into failing that sill, netting me at least half a day's work.
But i didn't.
I don't interfere with his opinion on any test.
And since he never earns the repairs on any car i take to him, the owner of the car is always assured that any allowed discretion will always be of advantage to the owner.
But the new tester you have chosen has decided to fail the sill.
His prerogative obviously.
Whether there was any financial incentive in his decision i don't know, and i'm certainly not making that suggestion.
Whether he was being over harsh, again, i don't know.
All we know is that nearly 5 years after deciding to
"sort it later", later has arrived.
So, to the repair.
Can be tricky, and on average about 4-5 hours work.
Made much easier since the guy in Kent started producing excellent-fitting repair panels at about
£70 per side
(set of 3).
From what i've heard, you posted picture/s
(but i presume have since deleted) of a repair and were questioning it's quality.
Here's a couple of pics of one i did a few weeks ago.
Total cost
£360 inc.
panels, Galvafroid inner sill and Waxoyl cavities
If your repair looks something close to the pics, then it sounds like a good job.
If it doesn't, then take it back and get it done to your satisfaction.
I really can't see what you're griping and moaning about.
You knew that sill was going to need work, and now it does.
Few hundred quid, job done.
FFS, you've lost more than that on xxxx parts you've bought, fitted, removed and sold in the last year or two.
