I've done one side completely with diodes etc, the other side I've only done the twin filament conversion but not diodes yet, I am following this guide:
http://www.mr2oc.co.uk/know-your-2/mk2. ... bartid=211
I wanted to try testing the lights first before completing the other side, to make sure they work which they seem to albeit temperamental, i.e.
Will not having all the diodes connected cause this?
I also have the fog light switch disconnected as it is broke and will be getting a replacement, could this have any bearing on causing issues?
Last but not least, I've got the diodes in the picture below, hoping someone can confirm which way round they go? I've got the grey side closest to bulb holders just now, is this correct?
