Bedford Autodrome MSV 19th June
Anyone else going to Bedford? I'll be there in my rev3 turbo
Re: Bedford Autodrome MSV 19th June
I might book onto this, is it the GT Circuit?
I've got a wedding/honeymoon to get out the way first but if funds allow it I'l be keen to get back out on track
1998 MR2 Rev5 NA
(Road
& Track)
1998 Porsche Boxster 986
(Weekend)
2007 Ford S-Max Titanium
(Family Hack!)
HughesR1 wrote:I might book onto this, is it the GT Circuit?
I've got a wedding/honeymoon to get out the way first but if funds allow it I'l be keen to get back out on track![]()
Yes it is the full GT circuit.
Have fun, check your brakes, coolant and oil beforehand.
I think it's a fun track.
(cos it's safe for noobs like me)
Its the perfect track for a trackday noob, practically impossible to hit anything and has a good mix of fast chicanes, tight corners, and decent straights.
I've found on a hot day it can be quite brutal on the cooling system as a fair bit of the track is wide open throttle, but as long as your cars in shape and you let it cool off every now and then you'll be fine.
1998 MR2 Rev5 NA
(Road
& Track)
(Weekend)
(Family Hack!)
HughesR1 wrote:Its the perfect track for a trackday noob, practically impossible to hit anything and has a good mix of fast chicanes, tight corners, and decent straights.
I've found on a hot day it can be quite brutal on the cooling system as a fair bit of the track is wide open throttle, but as long as your cars in shape and you let it cool off every now and then you'll be fine.![]()
Thanks for the advice, hopefully the car should be up for it, I've done a fair bit to it in recent years so hopefully I'm the only weak point.
The wide open track and few barriers is why I chose Bedford.
Any more nuggets of wisdom are welcome
Lefty1991 wrote:HughesR1 wrote:Its the perfect track for a trackday noob, practically impossible to hit anything and has a good mix of fast chicanes, tight corners, and decent straights.
Spend lots of time on Youtube learning the track, preferably with a map for reference.
It's a great track.
Otherwise, make sure you keep an eye on your track etiquette.
2001 BMW M5
(Bahnstormer)
| 2004 RX8 231
(the Racecat)
| 2001 Volvo V70
(Swedish eBay barge)
Previous:
1989 MR2 Mk1b T-bar
| 1988 MR2 SC Super Edition
Previous:
1989 MR2 Mk1b T-bar
Ben wrote:
If there's a
'slower' car that keeps catching up with you in the twisty bits, let them past.
Overtaking in corners isn't allowed, and as a driver of a relatively low-power but fast cornering car, it can be pretty frustrating sat behind someone who won't allow you to pass on the straight bits.
THIS.
Cracking track will defo have to get out there again
Very valuable advice
I can never find a proper circuit guide to the GT Circuit but I've got a vid from a few years back which should help you learn the track a bit.
Not one of my best laps but its a decent camera angle.
https://www.youtube.com/watch?v=d6xze5JwqI4
1998 MR2 Rev5 NA
(Road
& Track)
(Weekend)
(Family Hack!)
HughesR1 wrote:Very valuable advice^^^
I can never find a proper circuit guide to the GT Circuit but I've got a vid from a few years back which should help you learn the track a bit.Not one of my best laps but its a decent camera angle.
Cheers for that, Ive managed to watch quite a lot of videos to see the do's and dont's, great advice guys cheers
Now I just need to decide if there is enough tread left on the set of r888 I brought to last the day
Thank you for sharing the video, helped me a lot.
im looking into booking on this but slightly worried about the sound limits.
Has anyone taken a rev 3 turbo on here before with decat and aftermarket exhaust?
I've been to brands hatch
(92db driveby) and silverstone and never had an issue with tripping a driveby
- this is without even putting the baffles in.
Whats the chances that I'll trip this, even with the baffles in?
I did some test the other day with my car.
Berk decat and mongoose exhaust and got 94db static and 82db drive by,
I have brought two baffles for
£30 just incase but don't reckon I will need them
Bedford Autodrome are very serious about their noise levels.
It's a giant PITA
I took a mate's Del Sol with a B18C6 and decatted standard exhaust
- it was still too loud and I had to spend until about 1pm shoving whatever I could find into the exhaust system to make it quieter
The lack of power when I finally made it on track was disappointing to say the least.
Yep and I emailed MSV to confirm the one strike rule.
They won't even give you the chance to come back in and put baffles in.
I've decided to go back to brands instead as they offer you a fair few more chances, better than than losing your cash on the first lap
I agree that Bedford take the noise limits very seriously, but I've actually been told off for noise there before and still been allowed back on track.
They're always going to say its a
"one strike and you're out" rule, but for me they held up a big board that said
"NOISE" and told me to lift off the throttle there.
That was for open throttle body induction noise which is usually more of an issue than exhaust
(For me atleast).
You can clearly see where the noise meters are at Bedford too
1998 MR2 Rev5 NA
(Road
& Track)
(Weekend)
(Family Hack!)
