- Complete engine
+ all ancillaries
- Gearbox
- shifter cables
- LSD driveshafts
- Hubs
- Complete EFI system
- ECU, sensors, resistor packs, coil, igniter etc.
- Clutch pedal
(do I also need master cylinder?)
- Throttle cable
- Engine wiring loom
- Passenger side wiring loom
- Mongoose exhaust system
- Stock intercooler and an aftermarket intercooler kit, looks to be a Greddy copy.
Additional parts for engine refurb
- BRD downpipe
- Greddy Profec OLED boost controller
- Exedy OE replacement clutch kit
- Gen3 3SGTE complete gasket and seal kit
- Replacement studs
/ nuts where required
- Stoney Racing complete hose kit
(ancillary and coolant)
- Walbro 255 fuel pump with MR2 fitting kit
- Water pump
- Timing belt, tensioner pulleys, hydraulic tensioner
- Driveshaft seals
- Rear wheel bearings
Am I missing anything obvious?
