All the valve stem seals have been done.
Started it up seemed fine.
Is it possible that a hose has been connected incorrect sucking oil into the intake??
Did I fail at the stem seals? Thing is with stem seals is it burns oil on start up more.
gavsdavs wrote:I had a 3s-ge in which all oil control rings had seized into the pistons.Consequently burned as much oil as it did petrol.
I don't remember compression test results but it burned oil like crazy.
[email protected] wrote:gavsdavs wrote:I had a 3s-ge in which all oil control rings had seized into the pistons.Consequently burned as much oil as it did petrol.
so all 4 went at the same time..
okay so i think thats what has happened here.
I dont think my work has failed.
seems like piston rings
