the previous owner told me he
the AC didn't work when i got the car, the belt on the unit is missing.
the reversing lights do not work.
Crazy95 wrote:Hi all, my rev 3 turbo will be in the garage for the first time since I've owned the car and there are numerous things to be done and any help/thoughts would be helpful.
the previous owner told me he"thinks" he got it serviced, so lets take that as the car not being serviced in the last year.
what should I get serviced other than the obvious?
the AC didn't work when i got the car, the belt on the unit is missing.from a look at the front radiator it would make better use as a drying rack for clothes.
I've asked the mechanic to remove the AC unit to save some dead weight.
he doesn't know how much labour it will take due to never doing this before.
anyone have any experience removing the AC? I'm mostly looking to get the bulk of the weight out the car.
the reversing lights do not work.the car has had a gearbox refurb from the last owner after he broke 3rd gear so I believe it might be due to this.
from talking with the owner before the last owner(an idiot) a rear fog light was fitted to one of the reversing lights which also doesn't work, hard to tell if these 2 problems are to do with each other.
Crazy95 wrote:Im a little ocd when it comes to weight saving, anything broken gets removed, fixed or replaced with better parts.![]()
Crazy95 wrote:Im removing the ac due to it being dead weight.Ive read that it weighs 20kg
Not exactly a stripped out car but every little helps.Im a little ocd when it comes to weight saving, anything broken gets removed, fixed or replaced with better parts.
Regarding DIY jobs, i have no experience with these things and i would like everything check and done properly the first time so its easier to learn
The brake pedal for example is very light to begin with then turns super heavy if more braking needs applying
auzzam wrote:Crazy95 wrote:Im removing the ac due to it being dead weight.Ive read that it weighs 20kg
I removed my front AC rad recently when changing my coolant rad.It definitely does not way 20kg, more like 5kg at a push.
I was able to remove it just by jacking the car up slightly but then again I was removing the coolant radiator first which gave me all the room needed.
