Anyone else fitted these and found that the front sits wayyyy higher than the rear?!
Rear tyre is essentially in the arch, less than a finger gap.
Front arch gap is about 35mm.
So looks very weird.
Relatively new Koni yellow shocks, 16" wheels.
I'm considering chopping half a coil from the fronts, of course making sure that the spring still perches correctly top and bottom.
Has anybody done this? I've read that you shouldn't cut
'square' format springs but the only alternative I can think is to lower a couple of tonne pallets onto the springs with my forklift and hope they compress a little
I'm looking to drop about 20mm further on the front to even the car out.
I can't see the springs
'settling' by that much.
Any photos on Apex springs might be helpful?
