Need help finding the correct
Confused by the different types of Application? Don't worry
Overall low tensile strength but can be moulded to the needs of the repair and can be layered to fix larger areas so putty is very good at the
repair of holes etc.
Comes with two tubes, epoxy and hardener to be used to create own mix for different needs.
J-B Weld products and epoxy adhesives is needed to get the best results.
Creates a perfect 1:1 mix of epoxy and hardener, for ease of use and novices.
Having problem with Fibre Glass? Try
Thats all from us today, if you need any help on our
Oilman
