I've got a bit of rust on my 2 that I have asked a friend to help with.
let's start with the sills.
Next we have the recesses in the boot on both sides.
Liam
outrun wrote:Have you checked the condition of your inner sills and to see if the#FoamofDeath is still present?
Your outers look to be rotting from the inside, out and yeah, those inner quarters need looking at.Cut the rot out and see where it stops, then get some clean lower quarters from a donor car would be my suggestion.
IMO given the rot you have already found, I would examine the inner sills and get the rear bumper off before deciding anything.
You may be better off with another car to start from.
I reckon that would go through a test ATM, though.
metallica fish wrote:I've almost managed to get the rear bumper off to get a better look.Can I hell get the bolts off that are inside the wheel arch
outrun wrote:metallica fish wrote:I've almost managed to get the rear bumper off to get a better look.Can I hell get the bolts off that are inside the wheel arch
The ones that hold the side strips?
