5 13mm p clips, probably got another couple of you need 6 or 7
25mm blanking grommets, got about 80 of them
rear undertray bracket
n/a driveshaft nuts
20mm i/d hose about 1.3m in length
8mm silicone pipe blanks
wiring pin, pretty sure this is the extra wiring pin you need when converting a uk spec car to folding mirrors for the retract mirror button to work
0.9bar coolant cap
4mm vacuum hose, approx 60cm long
rev3 remote locking fob
20mm open wiring grommet, about 80
it'll all be going in the bin if it's here by monday
chris
