Bigger front brakes?
What options for upgrading front brakes on rev1 auto import?
Eg do supra brakes bolt up??
Too weird to live, to rare to die
Re: Bigger front brakes?
What power are you running that you need Supra brakes?
I think rev 2 fit on, but what ever you do for the front you must do for the back.
Otherwise it makes no sense and your braking will be all messed up.
Rev2+ brakes are an upgrade
300zx Z32, Skyline R32 calipers I've read somewhere fit with supra discs but you need brackets made up.
Going to have 1mz fe vvti done by Paul woods and wanted to know what
Upgrade are possible,supra brakes might be OTT
Rev 2 sounds better idea,oh and turbo lid was bang on cheers pal although
I dropped it off at paint shop 3 weeks ago and still not got it back lol
My painter is very busy man
I have a set of rev 3 turbo drilled discs, callipers and red stuff pads, pm me if interested, should give you what you are looking for
Limiting factor for non standard setups will be the size of your wheels.
Some brackets sold here
http://www.deltav.com.au/index.php/comp ... 2&Itemid=5
Swapping out the rev1 units for the larger items from the rev2
& onwards cars is a very noticeable improvement.
Add some braided lines whilst you're about it and you'll be set.
Just ensure you have a min of 15" wheels to fit over them
and remember to change the spacesaver from the 14" standard as well!
Not sure but TCB sells recon calipers as well as new discs etc maybe he'll take the rev1s in exchange for rev2s but check with Trevor first.
Great mod for any rev1.
R
R
benjo wrote:Rev 2 sounds better idea,oh and turbo lid was bang on cheers pal although
No worries dude
Will be good to see it all finished
