I've spoken to the owner and know it needs a cambelt change.
My thoughts are that it's probably worth the asking price looking at what else is on the market but any thoughts to help me take the plunge would be appreciated.
TIA
Pete
Martin F wrote:It is quite a lot of money for what it is, you will only end up wanting it to go faster, spending£1500 on mods only to wish you bought a rev 3 turbo.
The chances are the brakes will be fine after a wee drive, if not callipers can be had second hand for£50 with them being a very easy diy job.
Mileage is worth a little when selling, as is one owner, things still wear, engines last the life time of the car, timing belts, brakes, wheel bearings, clutches, brake lines, bushes etc.all degrade over time.
Two instances, my mums car has 34k miles on a 53 plate, it has many faults, I have a 6 year old runabout with 32k miles, it is needing a wheel bearing, front brakes, new exhaust and a nearside driveshaft(all which will be done in the next month),
that's my 2p anyway
rgb wrote:it looks alrightbut its not cheap.
if youre going to keep it for a few years its not that expensive.
you need to know what they're selling for
not what they're advertised at.
Martin F wrote:What about this?
In my eyes would be a much more worthwhile buy![]()
Charged wrote:£1100 sounds a lot for cambelt and brakes.
Link to car?
TurboPete wrote:Charged wrote:£1100 sounds a lot for cambelt and brakes.
Link to car?
I was quoted£450 for the cambelt.
£550 was for a full overhaul, discs, pads, calipers and brake lines.
£140 if just the pads needed changing.
Charged wrote:TurboPete wrote:Charged wrote:£1100 sounds a lot for cambelt and brakes.
Link to car?
Might be worth getting some comparitive quotes, my local specialist is£300 ish for a cambelt.
300 including all parts? That seems cheap.I assume they are not bothering with the water pump and hydraulic tensioner at that price?
rgb wrote:I had a cambelt done by Toyota in 2005 and it was 450 quid
