The replacement door is the skin only so all the mirror, electrics, window, etc need to switch across.
Is it easier to switch doors then switch everything across or easier to do the assembly on the bench then bolt on the complete door.
The replacement door is white
The vapour barrier plastic looks tricky as it's stuck on with super sticky black stuff.
thanks
