Does anyone know how thick the rear firewall is? Need to drill through to mount an amp. Will be using M6 bolts. Just wondering if it's thick enough to be able to use a tap to create a thread, and how long the bolts will need to be.
The bulkhead between the cabin and engine bay? If so then it's double skinned with some PU sealant type stuff between the two skins, it is at the top at least anyway, as I found out when I mounted the eye bolts for my harness
You can drill straight through and nut and bolt it fine i did my old amp that way just allow for the carpet being surprisingly thick and needing a spare pair of hands
