Rev3 Turbo Wastegate Actuator
Nic
Post by Nic »
1995 Rev3 Turbo
I may need a new CT20B wastegate actuator, it looks like Toyota don't sell them separately, are there any aftermarket ones that are recommend?
Nic
[email protected]
MR2 Rev 3 GT Turbo
Re: Rev3 Turbo Wastegate Actuator
You could go with a forge item, but I'd just source a second hand oem one.
When I changed my CT26 hybrid for a CT20b, I bought a second hand CT20b actuator off GTS chris. Spot on. :thumleft:
Willenium
Post by Willenium »
Can you not buy stock actuators at all anymore then? I have a Forge on my old CT20b but with the spring it has in it the minimum boost was about 16psi upwards.
Nic
Post by Nic »
Willenium wrote:Can you not buy stock actuators at all anymore then? I have a Forge on my old CT20b but with the spring it has in it the minimum boost was about 16psi upwards.
The Toyota EPC doesn't seem to list the actuator separately, only the complete turbo assembly, (same as they do with the Supra.)
Nic
[email protected]
MR2 Rev 3 GT Turbo
Willenium
Post by Willenium »
Have you tried going to a local motorfactor and asking if they can get parts from a company called Blue Print? When I order parts from my motorfactor they know to order from them as the parts are regarded as OE standard. Might be worth a shot.
