spigot rings what size
tonym
Post by tonym »
what size spigot rings for kei force 10 alloys does anybody know ?
they have to be 60.1 to ?
Re: spigot rings what size
60.1mm is the Mk2s hub flange diameter. You need to measure the diameter of the hole on the back of the wheel. If it's say 70mm, you'll need 70-60.1mm spigot rings. :thumleft:
SonicSW20
Post by SonicSW20 »
Most aftermarket wheels are 73mm centre bore. You should always check the specs / measure first though.
Nic
Post by Nic »
A Google search of 'Kei racing wheel centre bore' suggests it's 73.1mm
Nic
[email protected]
MR2 Rev 3 GT Turbo
