Ok so, I've bought a new exhaust manifold for my rev 3 turbo, buuuuut due to me using a rev 2 block the oil filter is totally in the way
So, simple right? Oil filter relocation kit.
Uhhh nuh.
I still dont have enough clearance between the manifold runners and block/oil cooler to fit an oil take off plate.
My question(s).
How
'necessary' is the stock oil cooler? Can I just delete it and use a shorter oil filter bolt
(taken from a non oil cooler car) straight from the block? Will I need an
'aftermarket' oil cooler or can I run without one?
