Best tyre pressure for Rev2 / Rev3 Turbo
Rob
Post by Rob »
What's the best tyre pressure for a Rev2 or Rev3 Turbo for general road use people?
Running 17" tyres if it makes any difference.....
JD
Re: Best tyre pressure for Rev2 / Rev3 Turbo
Post by JD »
29psi front / 33psi rear I believe :)
jimGTS
Post by jimGTS »
all depends on weight loading of the tyre
compare stock to your specific tyre and size
there are tables online you can look at.
but give or take a psi JD is pretty much on the money.
I run 30f/32r.
Nic
Post by Nic »
There isn't really a right answer to your question, it depends on the type/size of tyres fitted and road conditions. I'd start with the factory pressures which are 2bar front and 2.3bar rear, then add or subtract a little pressure and see how it effects the handling, braking and ride quality until you find a setting you're happy with. In the summer I prefer slightly higher pressures 2.1bar and 2.4bar with my 16" Toyo T1R's, but in this colder wetter weather I've reduced the pressures back to standard.
Nic
[email protected]
MR2 Rev 3 GT Turbo
Rob
Post by Rob »
Thanks everyone
