I am looking for the wiring for the one at the top of the exhaust system just after the wastegate.
Some bodger who plumbed in this engine into the car before me has cobbled together some of the wiring with the wrong and bad connectors.
The crap crimp he had put on the top lambda sensor has come off so I need to locate the correct wire/plug to connect it back too.
Anyone know if you can get the proper Toyota plugs anywhere also.
Not asking for much but if you could post a pic of the connector and wiring it would be very greatfully received.
