Rev1 vs rev3 suspension
Does anyone have a visual example of the differences between these suspension setups? Mine had stocks swapped back from Coilovers before I bought it so just want to make sure they were rev3 upwards.
Are rev3 the same as rev5 with regards to suspension?
Re: Rev1 vs rev3 suspension
I don't have a photo but the shocks are the same and the rev 1 springs are taller.
There is also a difference in the top mounts with one of them being off centre but not sure which way around that is.
Apart from the height of the springs the main difference between rev1 and 3 is the subframe and rear tie rods with the rev1 being adjustable.
Hth
Hth
abovetherim wrote:I don't have a photo but the shocks are the same and the rev 1 springs are taller.There is also a difference in the top mounts with one of them being off centre but not sure which way around that is.
Hth
I was just hoping for an easy way to see whilst they are on the car really.
If you want to take some pictures of your set up and post them up we can possibly tell you what you have.
You won't be able to tell visually very easily if you have Rev1 struts.
Rev1 springs will make your car look like a 4X4
Earlier front top mounts are offset but I'm not sure you can still buy those.
Most aftermarket ones are central.
stuMR2lee wrote:If you want to take some pictures of your set up and post them up we can possibly tell you what you have.You won't be able to tell visually very easily if you have Rev1 struts.
Earlier front top mounts are offset but I'm not sure you can still buy those.Most aftermarket ones are central.
That sounds like a cracking idea.
