well alien
- simple.
it wires in to your cutrosey light switches and your sidelights.
run a wire from the fidelight on the drivers side through the front boot, through the gromity in the drivers footwell.
take your next wire from the courtesy light switch.
run it under the trim on the drivers door sill mebbe need to dind an earth.
you can get one off the metal bracket where the hifi goes.
and that sunshine should be all your inputs, connect as necessary and secure your bleeper.
oh and do try to remember reversing trucks also male beep beep beep noises so do look out
